2003 S40
martin9586
- Year and Model: 2003 s40
does anyone know if the a/c fan under the hood is supposed to stay on the entire time the a/c is running or is it supposed to turn on and off as needed?
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
There are two and the larger one is a two speed and the smaller one a single speed.
ECM will run the large one on low at something around 200 psi and then go to high and add the small one at 250 +/- psi.
If it is a cooler day the car has cooled down the fan will cycle when you idle and the fans usually go off at a bit over 25 MPH due to air movement.
If a/c isn't on the fans will be staged based on how hot the engine gets.
- 1212 Views
Last post by alschnertz
- 727 Views
Last post by oragex
- 873 Views
Last post by steve090
- 1361 Views
- 957 Views
Last post by Vovo_merz
