850 Turbo
1994
arrow is blinking and when the computer is used to check for an error code nothing comes up. The car is running fine. I am driving the mechanic crazy because I keep taking the car back. Any suggestions?
Blinking arrow 850
If you're checking it through the OBD connector under the coin tray, you may not get any codes because of the reason that not all transmission codes trigger an engine fault.
Try the procedure described below.
http://www.volvospeed.com/CheckEngine.htm
Sometimes the mode selector switch (Win/Econ/Sprt) may trigger some bogus errors for the transmission system. Try clearing them as described in that page and see if it comes back.
Guest
Check the fuse under the hood. The fuse on my 850 somehow works itself loose...twice in three years.
bfm53
Just replaced a transmission sensor that was causing the winter mode arrow to blink indicating a transmission problem and also triggering the check engine light. this was recommended by my Volvo mechanic. so far so good.
- Has thanked: 2861 times
- Been thanked: 1332 times
Interesting... can you tell us what sensor, and how much it was for the part, and to have it installed?
Guest
Matthew,
The part is is called "PNP Switch". Volvo P/N is 9466012 and it lists for $125.78. My mechanic charged $75 to replace for a total of $200. So far the problem has not re-occurred.
Brian
Brian
- 1181 Views
Last post by precopster
- 217 Views
Last post by skloon
- 3614 Views
Last post by Jokerz
- 26 Replies
- 4752 Views
Last post by cn90
- 1429 Views
Last post by biohazrd76
