Bent Wheel-Big Issue??
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
brandonbeach14
Year and Model: 2.4T V70, 2001
Post by brandonbeach14 »
My wife ran over a huge pothole that bent the wheel out slightly on both sides and caused an egg on the tire. I replaced the tire, had the wheel balanced, and it's on the driverside rear. At high speeds there is a slight wobble. My concern is doing damage to the axle or bearings and not the tire wear. The cheapest replacement I found was $375 as they are the 17" wheels. I am also considering having the wheel repaired if needed. Thanks
brandonbeach14
Update: I have been told by the dealer and a senior memeber on the site that a slightly bent rear wheel is probably not a big issue and wouldn't likely damage the bearings or axle. It can cause the tire to wear uneven though. I was able to find several wheel reapirs shops varying from $85-$150. The wheel only has a slight wobble at high speeds and was more of an annoyance than a disruption in the movement of the car.
Juan62
Year and Model: S70 T-5M 1998
Been thanked: 2 times
Post by Juan62 »
check the volvo classified ads or Erie up top of this forum. E-bay too. You can get these very cheap.
98 S70 T5-M Brick for life
