2000 V70 AWD - Key stuck in ignition
VoVo
Year and Model: 2002
Post by VoVo »
For no apparent reason, the key gets stuck in the ignition, and when it does, I need to wait a while until something times out. Then the key is released. What could be causing this? Has anyone had this happen to them? What is the fix?
As always, thanks in advance.
VoVo
vitester
Year and Model: 1998
Post by vitester »
Sounds like the button on the gear selector is not releasing fully. They tend to get sticky.
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
Give your shifter a whack. Some WD40 sprayed around the edges of the knob and a paperclip to scrape out the gunk will usually get it working again.
'98 S70 T5
2016 Chevy Cruze Premier
db130
Year and Model: 2002 V70 T5
Post by db130 »
check the shift interlock button to see if it is in the fully raised position
2002 V70 T5 169k
2002 V70 NA 249k
2006 Mini Cooper S 90k
