1999 Volvo S70 problems
ashleyk2011
Year and Model: 1999 S70
Post by ashleyk2011 »
Hello everybody! I hope someone will be able to help me with this issue I seem to be having with my Volvo. I was running low on gas on day and on my way to fill up, my car died. It would stutter and start and then almost immediately die on me. I was able to get it running enough to get it into a parking space. It then died on me again. I thought I was too low on gas and it just wasn't going to run until I got some more gas in it. I got some gas in a gas can and then put it in. It seemed to be fine so I pulled out to go fill up completely. Not more than 5 minutes later, it died on me again. It did the same thing, it would start and then almost immediately stutter and die. My father thought I had gotten an air pocket in the fuel line somewhere. We once again managed to get it running and it seemed that the "air pocket" had worked its way out....not. Shortly after filling up completely, it died again. This has been a recurring problem for about a week and a half. My fiance and my father had replaced a fuel filter, cleaned out vacuum lines, replaced one vacuum line that was dry rotted and warped. But nothing seems to be working. They even replaced my gas cap because the seal was bad. What else could be wrong with it? They're thinking the charcoal canister or even the ECM. What do you think? Any help would be greatly appreciated!
Reason: Removed 'HELP!!!' from the title. Please read the forum rules.
da7
Year and Model: 1997 S70 N/A 20V
Post by da7 »
sounds like fuel problem, probably best to connect a fuel pressure meter and monitor fuel pressure when the car is starting, and on the way of choking and stalling.... most likely fuel pump, and/or relay...
babelfish
Year and Model: '98 S70 T5
Post by babelfish »
You could also check out the fuel pump itself with a voltmeter.
mtm3200
Year and Model: 99 V70XC
Post by mtm3200 »
da7 wrote:most likely fuel pump, and/or relay...
+1
I was having very similar problems and replacing the fuel pump relay fixed it
da7
Post by da7 »
babelfish wrote:You could also check out the fuel pump itself with a voltmeter.
but the fuel pump could be getting voltage from the relays but aren't pumping anything coz it's dead?
any news from the OP if the problem's fixed?
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
Is your Check Engine Light on?
Has anyone scanned for trouble codes?
