Location of temperature sensor on 1996 850 N/A
kaerlighedsbamsen
Post by kaerlighedsbamsen »
The temperature guage at the instrument panel is itermittently failing. Tried to locate the sensor and the appropriate wires but had no luck. I know this is a bit stupid but exactly where is it?
Thanks!
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
Time for a new ECT sensor (or check out the wiring).
It's located under the thermostat housing - follow the upper radiator hose over to the engine - the ECT is the copper plug at the bottom.
Change out the thermostat too as a preventative measure (they're cheap!)
https://www.matthewsvolvosite.com/2009/0 ... 0-or-xc70/
'98 S70 T5
2016 Chevy Cruze Premier
kaerlighedsbamsen
This is great! Picture and all.
Fiddled with the wiring and found that the connector to the sensor was dirty and corroded. Cleaned and sprayed with wd40 and the problem is solved.
Thank you so much!
