I torqued down my cam cover bolts last night while completing a HG replcement. I downloaded a service manual that gave a torque setting of 13 foot pounds. After reading that these were a bit delicate I slowly worked up from about 5fp and ended up on 10fp. The bolts felt like they were approaching their limit at that figure. (limit before stripping)
I now see a thread on here that states a max of 7Nm which is only 5 foot pounds. ??????
Can anyone clarify the correct torque please and whether i have over-tightened mine. Hopefilly the there are no implications for the cam sealant..........?
volvo 850 correct torque setting for cam cover bolts
Fix Leak at Tailgate Hinge and Roof Trim
christhekiwi
- Year and Model: 850 Turbo X 2
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
13 lb-ft , 17 N-m is the factory spec torque for those 7 mm bolts.
If you think the threads are compromised from corrosion or other you're probably not going to have problems if they are torqued to 10 lb-ft.
christhekiwi
".............not going to have problems.........."
so do you think 10fp is OK?
- 11 Replies
- 17587 Views
Last post by volvolugnut
- 1065 Views
Last post by piwikiwi
- 1299 Views
Last post by Nevada1906
- 2447 Views
Last post by andreivlas
- 1109 Views
Last post by cometphoton
