S70 PO442 Code
Juan62
- Year and Model: S70 T-5M 1998
- Been thanked: 2 times
My 98 S70 T5-M has a P0442 Code (Evap Small Leak): I should change the gas cap (new), and replace the J-hose on the evap canister on the rear (near the fuel filter). What is the part number for this J-hose anyone. I know this is a process of elimination...before I start pouring $$$ into purge valves and purge check-out valve. Thanks to all.
98 S70 T5-M Brick for life
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Is your canister mounted at the rear of the car or the front?
For rear:
9443308
http://auto-parts.fcpgroton.com/search/ ... ry=9443308
For rear:
9443308
'98 S70 T5
2016 Chevy Cruze Premier
Juan62
Hey Blackburn!
Its mounted slight in front on the rear (right) passenger side near the fuel filter. It does have some residue all over the hose. Also, what size clamps do I need with the J-hose? Thanks.
jblackburn
The number listed for the clamps is '988024'.
Honestly? Just pick up some adjustable screw clamps from an auto parts store. They'll do the job just fine - I use them for just about everything.
'98 S70 T5
I have had the PO442 code for the longest time. I was finally able to clear the code when I had my catalytic converter welded shut. The exhaust system can throw this code.....makes sense too. The rear hanger had rusted off, causing stress on the exhaust pipe at the back edge of the catalytic converter. Went to the local muffler man shop, had new bracket put back on,and the cat welded back together. Cleared the code with OBDll , and code has not come back on !
No need for a new j hose or gas cap.
IPD Sport Springs. Koni Yellows. IPD endlinks. IPD strut bar.
160,000 miles
160,000 miles
Juan62
Hey BifFinn;
I changed the j-hoses. I do see a few black spots on the exhaust system. Will go Midas and see what they can do for me. Thanks for you help....never thought about the exhaust.
- 93 Replies
- 28735 Views
Last post by foggydogg
- 25 Replies
- 5885 Views
Last post by Gerd
- 1949 Views
Last post by RickHaleParker
- 23 Replies
- 4773 Views
- 1841 Views
Last post by Vova585
