The rear drivers side spring broke on my xc70. I ordered a new assembly from the wreckers.
Does any one know the work procedure to install this spring assembly tower. If i remove the screw at the bottom of the strut, it looks like I just need to undo a couple of screws at the top of the assembly and one inside the car. Is there enough room for the shock to then slide out or do I need to take off the control arm, etc.
Advice for rear suspension removal...
Performance Nightmare Ended - Knock Sensors
2001VolvoXC70
- Year and Model: XC70 2001
They've done studies you know. 60% of the time I work, every time!
2001VolvoXC70
Alright since no one else has seemed to attempt this repair, I will update you on the reality of trying to swap your rear suspension assembly. I found out that it is possible to do with 2 jacks, 2 people and alot of determination. This is how I did it;
I started by jacking the car up and putting some wood underneath to rest the car on so it would be very stable. Then I removed the 4 screws; 1 at the bottom of the strut tower, two at the top of the strut tower bolted to the top of the wheel-well, and then the one inside the car with a crescent moon like washer. My spring had broke and was resting on the control arm. This was under alot of pressure and was holding my car up. I used alot of force to get it off but be carefull not to injure yourself when it finally springs out of its place. Once the spring has released its tension, you can manipulate the assembly in a way to remove it from the space it is resting. This is not easy as the space is cramped and the area to work with is small. I had to remove the broken spring off the assembly, and then slide it out.
Putting the new assembly in required lots of diligence and determination. Place the spring assembly (tower) in the space and if you can remember which way you took the old one out attempt to put the new one back in the same way. The top of the tower is a very tight fit and took me about 15 minutes of manipulating. I ended up taking the bolt off the control arm and my brother would move the brake assembly up and down a bit while I forced the spring assembly into place. Again this is quite the challenge and I thought I was going to have to give up. But where there is a will there is a way!
Once you have accomplished the most difficult, you now have to jack up the bottom of the assembly to compress it so you can re seat it on the mounting. This too is a bit tricky. It took me several attempts to jack up the spring to get it in a location close to the mounting pin. Then I had my brother push down on the rear brake assembly to get the pin unto the mounting hole on the bottom of the strut. I was able to get the bolt in and this pulled everything in place. Remember that the spring is under pressure from the jack and if it was to release that pressure some way, it could potentially hurt you. After mounting the bottom I then had to mount the top. I had to bang it a bit with a hammer and crowbar to line up the holes and Voila! Remount the control arm and tighten everything up, and you are good to go!
In conclusion, what seems to be a straight up job is actually fairly difficult. I don't know if I would attempt this again, it may just be easier to take it to the shop and ask someone there to do it.
- 582 Views
- 399 Views
- 12 Replies
- 3352 Views
Last post by RickHaleParker
- 1759 Views
Last post by vtl
- 960 Views
Last post by famfeld
