bad oil leak on c70
bad oil leak on c70
hiya i have a c70 with a bad oil leak at rear of engine,but i cannot find where its coming from,ive had car up in the air on axle stands and put it in drive so i could look for leak.cannot find it anywhere.any ideas please thanks. oh car has150,000 miles and is a 2001 model auto
FCPEURO
- Year and Model: 2006 XC90 V8
- Been thanked: 19 times
What I would do is clean off all the oil that has gotten on the engine, run the car for a little bit and then take a look again to see if you can see where the leak is coming from. Without cleaning up the oil, it will be very hard to find the leak.
tigmaned
- Year and Model: blacked-out V70 04
one thing that might have started this issue???
have you checked your (PCV) volvo calls it a flame trap system.
a quick test- with engine running, take off oil filler cap, with your hand covering the opening you should feel a little sucking from the engine. if its pressure comeing out that might be part of your problem? engine pressure is finding another way out from a old gasket??
