So the wife is driving the car and of course something goes wrong. No A/C. Well come to find out, essentially the blower is not working. Last year we had the blinking issue a couple times but everything seemed to resolve itself after turning off the car.
I attempted to troubleshoot this so I checked the fuses, and also pulled the cabin filter only to see zero movement. So I figured why not tap it a little bit see if it moves. With the car off, it moves what seems to be smoothly. With the car on, I taped it and got it spinning with the screwdriver and it continued to spin. It goes off after a minute or so, and doesn't ever reach a high speed. Am I looking at a blower motor being the issue or something else. I figured if something else was shot it wouldn't ever kick on at all or am I totally off base?
I did pull the glove box, pull the connector to make sure it was seated properly but that didn't seem to fix it. Any ideas?
Blower motor or something else???
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
It sounds like the bearings have gone out in the motor. Most motors have a thermal cut-out switch built into them that will turn the motor off if it starts to overheat (for example if it was having to work real hard against bad bearings).
'98 S70 T5
2016 Chevy Cruze Premier
- 1608 Views
Last post by bugeye
- 12 Replies
- 5645 Views
Last post by darrylrobert
- 13 Replies
- 5481 Views
Last post by oragex
- 13 Replies
- 4279 Views
Last post by erikv11
- 2782 Views
Last post by cn90
