I dont have any light that shows when you are in PRND on the stick shift...... Is this an easy fix? Any DIY pics?
Also, right side of speedometer and left side of the RPM gauge lights are out.
Thanks
brad 98S70 130K
no lights on shifter?
Jack Rock
- Year and Model: 1998 V70R
For you PRND light check this out
http://volvospeed.com/volvo_repairs_how ... ement.html
For the speedo light check this out
https://www.matthewsvolvosite.com/2010/0 ... lb-change/
1997 850 T5 (gave up at 324,000km)
1998 V70 R AWD (gave up at 296,000km)
1998 S70 T5 (total loss - in a parking lot!)
1999 V70XC
1975 VW beetle
1960 Empi Sportster Dune Buggy
1999 V70XC
1975 VW beetle
- Year and Model: Many Volvos
- Been thanked: 76 times
The lamp socket for the shifter light is a unique socket and they are stupid expensive from the dealer. I have fixed mine by soldering in new lamps from Radio Shack - part number 272-1092 - into the old OEM lamp base. They run around $2.00 for a 2 pack. The ring around the cigarette lighter uses the same lamp so I replace both of them while I had the console off.
A Dremel tool with a cutoff wheel makes nipping the old lamp wires very quick and easy and then you can thread the leads back though the OEM holes in the base.
Thanks for the input. Just finished, but I don't like the way you just shove the bulb up into a plastic hole. It's all buttoned up now but I wish I had put some tape around the socket to hold it in place. Seems like over time gravity may push it out.. And you say: it was in there for 13 years and it didn't fall out so why now! I say: Murphy's Law...
- 7978 Views
Last post by oragex
- 5032 Views
Last post by virtualking
- 3587 Views
Last post by BEJinFbk
- 1354 Views
Last post by Adam_Leyva
- 2831 Views
Last post by candice_joel
