wheel hub
This topic is in the MVS Volvo Repair Database » Aftermarket Heated Seats
bumpbump57
Year and Model: 940Tubo 1994
Post by bumpbump57 »
I have a 94' 940 turbo. While replacing a rusted out protector plate the race from the inside bearing came through the Hub. I am trying to put it back, but, I am thinking I should just buy a new Hub. What do think?
Thanks for the reply.
petek153
Year and Model: 1992 940T
Post by petek153 »
I would just buy a new hub I believe if it fell out its worn and should be replaced 99 bucks for a new at FCP or maybe local supply shop bearing I would think be contaminated if its open usually they are a sealed unit
92 940 turbo
93 850 GLT sold
94 850 GLT
96 850 GLT my parts car (:
96 850 T_BONED ):
97 850 BASE
bumpbump57
THANKS PETEK153, I did just what you suggested and bought one from FCPgroton. Just got back from vacation and now how to put everything together. I bought two replacement brake lines also and I am now searching for a ABS bleeder.
thanks again
petek153
Post by petek153 »
I just use a helper to bleed the system the old fashioned way. Pump the brakes up crack the bleeder with a clear hose attached watch for bubbles ,tighten bleeder before pedal is released then repeat till all air is out. Start with farthest away from master cylinder first make sure you don't run out of fluid or you'll have to start again.
92 940 turbo
93 850 GLT sold
94 850 GLT
96 850 T_BONED ):
97 850 BASE
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
One word of advice on brake bleeding: disconnect the vacuum check valve from the brake booster while bleeding.
1988 Volvo 760 Turbo Wagon
bumpbump57
The old fashion way is the only way I know how to bleed brakes. Thanks for the advice and the advice on the vacuum check valve. I saw an ABS brake bleeder for $58 is it worth it? I have two 94' 940 turbos. thanks
