Erratic shifting
VolvoFreak
Erratic shifting
Post by VolvoFreak »
Doesn't happen all the time, in fact, it's uncommon, but every so often in my '93 GLT my tranny shifts "funny". For instance, last time it happened, I was going down a long hill and it shifted out of overdrive like it was engine braking. Another time I was in the city and it seemed to slip between 3rd and overdrive a touch - thats happened 2 or 3 times. Also, a couple of times while going up hill, it shifted out of overdrive like it should have, but didn't shift back in even if I took my foot of the gas. No codes are shown and fluid looks and smells perfectly fine.
1993 850glt
219,000+ miles and counting :)
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1254 times
Post by matthew1 »
Fluid level checked? Remember to check while car is idling, warm, on level surface.
Also -> Amazon link
VolvoFreak
matthew1 wrote:Fluid level checked? Remember to check while car is idling, warm, on level surface.
According to my mechanic, the fluid level and quality was fine (I should check myself though). Actually, the tranny was power flushed about 5k miles ago...
1993 850glt
Guest
Post by Guest »
"...I was going down a long hill and it shifted out of overdrive like it was engine braking."
I've always considered that normal (by design).
VolvoFreak
Guest wrote:"...I was going down a long hill and it shifted out of overdrive like it was engine braking."
It very well may be normal operation.. The only other Volvo I've ever owned was an '88 240dl. That's one reason I posted, to see if it was normal. I mean, as far as front-wheel drive vehicles, the only one's I've owned were an '84 Pontiac Sunbird and '86 Olds Delta 88 which never did that. Everything else have been rear-wheel drives and I've only had my 850 for about 4 months.
1993 850glt
