1995 940 Wagon (non-turbo) - Vacuum Tree Location
I want to seafoam "Black Betty" but I am starting to think she doesn't have a vacuum tree. Can anyone tell me where the vacuum tree is for a 95 940 wagon? If there is not a vacuum tree what is the best way to seafoam? Thanks.
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
if you barely open throttle the small diameter line on throttle body has vacuum. It is ported vacuum so the hole is in front of a closed throttle and then the opening throttle passes it with very little throttle opening. This line goes to the vacuum operated charcoal canister purge valve.
- 16 Replies
- 6959 Views
- 361 Views
Last post by CFL850T
- 222 Views
Last post by veezmachine
- 292 Views
- 826 Views
Last post by Pmckib
