How do you change the Position/Parking bulb?
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Boff
Year and Model: V70 D5 2002
Post by Boff »
Hi All
The right hand, rear position bulb on my 2002 V70 D5 SE needs replacing. This happened a while ago so I gave it a slap and it came back on for about a month, then went out again, slapped it again, worked, then went out for good.
So, this morning, over 2 hours ago, I thought I'd finally replace the bulb. Looked on-line and was really impressed at how easy it is to twist the huge handle things, pop out a bulb, pop a new one in and away you go. Not so. It's the top bulb of the lower cluster which, for some reason, has a different thing holding it in that won't budge, doesn't twist and requires all the skin off your hand before you get anywhere. I've got to the no skin on my hand stage and that's it :evil: :evil: :evil: . Can someone tell me how I change this bulb?
Many thanks
Joe
Volvos rock3
Year and Model: v70xc, 2002
Post by Volvos rock3 »
There are two access points, either through the speaker or the carpeted panel below. On our 02XC all of the rear bulbs have the twist out holder. it may be stuck with corrosion. And yes there is alot of my skin in that compartment as well.
1996 850 GLT sdn (deceased)
2002 V70XC 118k
2009 S80 3.2 37k
1998 Chevrolet K1500 84k
1965 Pontiac Lemans convt
2009 Chevrolet Tahoe PPV 2x (work)
