O2 Sensor Topic is solved
This topic is in the MVS Volvo Repair Database » XC40 Recharge Photos
850 T5
O2 Sensor
Post by 850 T5 »
I am using Alex Pepper's software on both my 1997 850 GLT and 1997 850 T5.
I have no CEL on, however, my mileage is terrible on the T5.
I have done the tune up (plugs, etc) and have checked the MAF connector.
The GLT has readings for Bank 1 and Bank 2 oxygen sensors.
The T5 only shows Bank 1.
Could the lack of a Bank 2 reading on the T5 indicate a bad sensor, even though there is no CEL indicator?
Jot
Year and Model: C30 2010
Post by Jot »
Are you getting black smoke? have you checked for air intake leaks useing an unlit propane torch?The MAF reads the amount of air telling how much fuel to add. the O2 sensor reads the exhaust to see if has been properly burned and the second O2 checks that the cat has done all that is necessary for the emisions to be correct. If all are in proportion no CEL.
White850Turbo
Post by White850Turbo »
850's don't use the bank system. What type of mileage are you getting? If it's real bad, I bet anything it's a vacuum leak.
-Sean
1998 S70 T5 (Almost Stock)
850 T5
Post by 850 T5 »
I am geting about 18 mpg overall (city/hwy).
There's no smoke, black or otherwise, however, there is some black soot buildup on the tailpipe.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1254 times
Post by matthew1 »
850 T5 wrote:I am geting about 18 mpg overall (city/hwy).
A little below what I get (22mpg). Check vaccum lines like W8T said. They are thin white plastic lines in the engine bay. Check elbows also.
850 T5 wrote:There's no smoke, black or otherwise, however, there is some black soot buildup on the tailpipe.
Normal, I have the same, and I see 850s everywhere with sooty pipes.
Also -> Amazon link
