tranny seal on rt. cv shaft. Can't stop the leak.
I put a remanufactured cv axle in the right side of my 02 s80 T6. It was seeping some fluid so the local dealer replaced the seal @ $330.oo. Still leaks. Took it back and he said the remanufactured shafts are polished below tollerance and sometimes don't seal. I picked up a used shaft and the diamater is just about the same. It's about 44.09 mm. The reman is about 44.03. Is that little difference enough to cause the leak or can it be somthing else?
travismail1
- Year and Model: S80
I have the same issue. Replaced with two Napa reman axles and two OEM seals and it still leaks. I believe you are right with the polishing theory. Do you have any further updates?
travismail1
The second I am leaning toward is the carrier bearind on the shaft that has not been replaced during the remanufacturing process is worn causing the axle to wobble ever so slightly during rotation which is effecting the axle seal to leak from the movement?
travismail1
okay, i replaced with another reman axle and another new seal with same result. I did have the transmission rebuilt not to long ago and now I am leaning toward movement in diff. of something in that direction. Does anyone have knowledge with tranny rebuilds?
- 5004 Views
Last post by Amk20155
- 3607 Views
Last post by bluesguys80
- 5361 Views
Last post by SuperHerman
- 709 Views
- 20 Replies
- 9787 Views
Last post by JimBee
