OK, maybe it is 10, not zero, but what's the difference.
See this thread - been running a 100k junkyard engine for a few days now. It has been running very smoothly, up to about 150 miles now since I started it. Still on the first fillup of dino oil, 10w-30. So I am sitting at a stop light a few blocks from home tonight, car starts running rough. Chug it home, CEL comes on, P0302.
Fearing the worst I immediately go to my compression gauge. #2 gives me almost no reading.
two days ago: 200-210-190-180-205
two hours ago: 205- 10-195-200-205
There was no blue smoke last 100 miles, no smoke at all in fact. Somebody please tell me this is just carbon, and not a burned valve, and more importantly how I might quickly figure that out without pulling the head. Maybe I need to get ahold of a camera.
#2 compression went to zero
- Has thanked: 311 times
- Been thanked: 817 times
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
It could just be a stuck valve/lifter.
Drive around for 3-5 minutes in a low gear above 4000 RPM and see if it frees up.
'98 S70 T5
2016 Chevy Cruze Premier
OK that didn't change it, any other thoughts?
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
The fact that all of them are okay, except one is not good... If they all had low compression, then maybe the sticky lifters would be to blame. But since you had good compression just a couple days ago, I'd say this is not good news.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
vjaneczko
- Year and Model: 2006 S60R
- Been thanked: 7 times
Did you run SeaFoam through it? I didn't see if you had in the other thread.
The oil you have; does it have any cleaners or stuff for high-mileage engines? If not, I'd change it to something with additives. Hopefully jblackburn is right...
1997 855 GLT - R.I.P.
2006 S60R - For ME!
2006 S60R - For ME!
jblackburn
Stick your hand on the exhaust pipe as its running (and the exhaust is cool
). If you feel it sucking in, there is a burnt exhaust valve.
You can also bring the #2 cylinder to top dead position (by rotating the crank around) and use an air hose/compression tester fitting. Listen for air out the exhaust.
'98 S70 T5
OK, I can do the leakdown test after lunch.
But will that distinguish between a stuck valve and a burnt valve?
boosted5cyl
- Year and Model: '98 V70 T5, '99 S80
Jblackburn made some good suggestions, although rather than using your hand for the exhaust test, use a piece of cardboard. Or bring it to TDC on the compression stroke and get some compressed air in there. You dont even need a leakdown, just listen to where the air is getting out.
In terms of checking weather its stuck or burnt you can....
Try and get a borescope in there
Pull the cam cover off and take a look
Remove the exhaust manifold, take a peek
Might well be better ideas out there, these are off the top of my head.
'04 XC90 2.5T AWD (Angus) 134K.
'99 S80 T6 (Medusa) 214k. On borrowed time LOL
'98 V70 T5 (Vivienne). RIP @ 228K. Spun rod bearings.
jblackburn
I just re-read your initial post, and two things make me think lifter:
1) It sat for a long time and made lots of noise at startup.
2) It's not dead "zero" compression.
In terms of diagnosing stuck/burnt valve:
https://www.matthewsvolvosite.com/forums ... =1&t=30063
http://www.pistonheads.com/gassing/topi ... e%20please
Since the high-RPM driving seems not to have helped it, the Seafoam or AutoRX might clean up some gunk on the valve stem that might be keeping it from closing.
If all else fails, you'll probably have to resort to yanking the head to find out for sure.
'98 S70 T5
boosted5cyl
If you suspect a stuck lifter, pull the cam cover off, check it and maybe replace it. They are cheap enough and easy to do. I guess you could hit up the timing belt replacement at the same time if it happens to be due.
- 10350 Views
Last post by FREEBUSINESSES
- 472 Views
Last post by GreenMagicMan
- 1736 Views
Last post by Livens
- 2456 Views
Last post by dux02v70
- 1056 Views
Last post by vtl
