Man am I struggling to find a complete timing belt write up. Anyone got the right one book marked?
Not sure why I do so poorly here with searches but I need a little help.
belt timing belt procedure?
carboncow
- Year and Model: 2003 XC70 2018 S60
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
1999 Porsche Boxster
2004 Chevy Suburban LT 5.3L
2013 & 2015 S60 T5
2008 Vw Touareg T2 V6
1989 Sea Ray 340 Sundander
2007 Sea Doo Challenger 180 SE
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
claymore850
- Year and Model: 850 T5, 244, V70 2.4
Take a look on this link...
https://www.matthewsvolvosite.com/forums ... f=1&t=8803
Enough info to complete the job, but take care and time, dont believe in your memory, make some drawings and marks, take pictures.....
carboncow
See Model/Year below username.
I've got a 01 and 03 both in needs soon or slightly past with 2.3 and 2.5 engines respectively...guessing these are identical.
I did see a write up for mid 90s but things looked different enough that I am hoping for the right procedure. I just looked at the procedure that claymore listed and it also appears to be for mid 90s stuff based on their comments.
I've done some Vw 1.8T and 1.9 Tdi (big pain)...I'll assume I should get the cam locks to make life easy? How about crank locks...are they needed?
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
I have been trying to find the timing belt procedure I found and printed from the internet for my 02 XC70. It was a very good article with pictures. The pictures in all the articles I have found show a different picture of the crankshaft timing marks than what is on my 02. The crankshaft timing marks are actually like those on the 2000-2004 S/V 40. Unfortunately, I have not been able to find the link to send you. You might consider replacing the water pump while you are at it. The timing belt drives the pump and has to be remove anyway. More of a preventative maintenance item than a necessity.
carboncow
Thanks. With all this amazing Volvo info out there I'm surprised I have not found a complete P2 write up with photos!
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
I found the link. http://www.volvoxc.com/resources/how-to ... ement2.pdf I didn't remove the crank pulley. There is a plastic cover behind the crank pulley that is held on by 2-10mm bolts. The bolts are on the side facing the radiator. Remove the bolts and you can work the belt around the pulley. Be careful not to kink the belt. I didn't lock the cams, but if you can it is recommended.
carboncow
That's what I"m looking for...thanks!
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
- 825 Views
- 12 Replies
- 8533 Views
Last post by Nathan79
- 5439 Views
Last post by jimmy57
- 23 Replies
- 17712 Views
Last post by jonesg
- 20 Replies
- 17676 Views
Last post by Hurtfeelings
