Loud metallic rubbing noise
itsnotageek
- Year and Model: 2002 XC70
I have a 2002 XC70, 120k miles. I recently changed the pads and rotors in the front. Previous to changing the brakes there was a slight rubbing noise that presumably came from the front. After changing the brakes, there is a NOTICEABLE rubbing noise coming from the car. The rubbing noise coincides with the rotation of the wheels, is not affected by braking and gets louder as I turn left, and goes away when I turn right. The noise is not constant either, it comes and goes. At first I thought it was a bent dust shield rubbing on the rotor, but I have removed the wheels twice and cannot find anything. There are not any rub marks anywhere, I checked the clearance of the dust shield, and everything looks perfect. I have checked, but not taken apart the rear brakes, could that be it? The noise is driving me insane!! Thoughts?
IronMike
- Year and Model: 2007 S80 3.2
- Has thanked: 5 times
- Been thanked: 6 times
Did you figure this one out?itsnotageek wrote: 12 Jul 2011, 10:51 I have a 2002 XC70, 120k miles. I recently changed the pads and rotors in the front. Previous to changing the brakes there was a slight rubbing noise that presumably came from the front. After changing the brakes, there is a NOTICEABLE rubbing noise coming from the car. The rubbing noise coincides with the rotation of the wheels, is not affected by braking and gets louder as I turn left, and goes away when I turn right. The noise is not constant either, it comes and goes. At first I thought it was a bent dust shield rubbing on the rotor, but I have removed the wheels twice and cannot find anything. There are not any rub marks anywhere, I checked the clearance of the dust shield, and everything looks perfect. I have checked, but not taken apart the rear brakes, could that be it? The noise is driving me insane!! Thoughts?
Davezx6r
- Year and Model: 2001 S60 2.4t
- Been thanked: 2 times
I had a similar experience with the xc that we bought a couple months back. Same thing only when I turned one way. Then it just started going non stop. I jacked up the car and realized the sound wasn't coming from the wheels. It ended up that the exhaust heat shield in the center tunnel had pulled thru the bolts and was laying on the axle. My guess is one side broke away first and was intermittently hitting the axle till the other side fell off too.
- 3876 Views
- 779 Views
Last post by Randall0208
- 522 Views
Last post by jonesg
- 2122 Views
Last post by CoupeC70
- 11 Replies
- 2069 Views
Last post by ThommyKent
