fan trouble
- Year and Model: Many Volvos
- Been thanked: 76 times
Which fan? The cabin HVAC blower or the engine cooling fan?
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
You may have the low speed not working. When that happens the a/c pressure goes high enough to trigger hi speed and then hi speed runs briefly and pressure drops and it reverts to low speed but low speed isn't blowing so the cycle repeats.
The fan relay is just under RH (passenger side) end of the fan shroud top plate. It slips out to the rear. The low speed trigger is yellow white and the hi speed is solid yellow. Make sure the Y-W hasn't slipped out of the grey connector. The plastic around those bullet connectors turns to goo with age.
If that is all good then disconnect the large gauge wire 2 wire connector. Use a jumper wire between battery and touch the connectors one at a time. You should be able to get fan to run at low and hi speeds. If this is all good then get a fan relay.
- 393 Views
Last post by Dottelito
- 1182 Views
Last post by neworleans
- 4077 Views
Last post by moacyr
- 15 Replies
- 2926 Views
Last post by Matty Moo
- 18 Replies
- 3386 Views
Last post by francisp
