This thread got too long and is now locked (you can't post to it).
Please start a new thread to ask an AC-related question that isn't answered here or on the Volvo AC Fixes page.
Official AC Thread
Volvo Air Conditioning Problems & Fixes
- Has thanked: 2856 times
- Been thanked: 1332 times
My 93 850 glt with electronic a/c will not blow as fast as it once did. I recently had the a/c recharged because the compressor was cycling. I added R-134-A, and now compressor operates properly and is very cold. Problem is now I have noticed that the fan will not blow very fast. When the interior of the car is hot, cold air will come out of the vents at medium speed at best. Even if I manually slide the fan speed selector over to the highest speed, medium is all I get. It used to be that if I did this, or turned on the defroster, it would seem 'Jet powered', but not now. I think it has been a gradual failure, so slow in fact that it went unnoticed until now. I also have noticed in the past, noise that would increase as the fan speed increased. Especially on high.
Question: I want to check the A/C codes, and find a key for those codes. What is the procedure for pulling the a/c codes. I am familiar with pulling codes for fuel injection and ignition, so I am not totally clueless.
Next, depending on what the codes reveal, I need to determine if the fan, the fan speed control switch or the fan speed resistor (if it has a set), are bad. Does anybody have a diagnosis procedure to follow?
Next, If it is the fan, is there a step by step pictoral that can be followed to replace the fan? I suspect the fan.
Thanks in advance.
Walter
Thanks in advance.
Walter
2007 XC70 21,000 Miles
1993 850GLT, bought new
133,500 Miles & 15 great years of service
850girl
So its the middle of summer and I can't go another second without recharging my A/C. I looked under the hood and frankly am totally intimidated by what I see. Can anyone give me clear directions to find the port that I hook this canister thing up to? I drive a '96 850 sedan.
I got the Interdynamics Arctic Freeze R-134a refrigerant+ from PepBoys
I'm thinking I can handle it once I find the port, but I have never done any thing on this car by myself except check the oil (its still dark and icky! jk)
Any tips on what NOT to do would also be appreciated!
https://www.matthewsvolvosite.com/ac_page.php <- This should answer your question.
First read the instructions that came with the kit, and I believe you hook it up to the LOW side of the AC. It should be connector called 70NM or something.
1998 Volvo S70 T5 Auto
1995 Volvo 850 GLT <- RIP
850girl
Thanks man! I saw the Nm thing and just wasn't sure that was what I was looking for... better to ask and be right than wrong and... well you know...
You rule!
You rule!
yeagermeister
- Year and Model:
mine's good for about 5-7 minutes, cycles off for about 2-3 minutes, then back on again. the longer i drive, the longer the intervals between cycles, and the shorter the cycles become.
i've added almost an entire 19 oz. can of R134a, and the pressure gauge reads around 60psi when i'm trying to fill it, drops to around 35-40 psi when i just hook it up and don't try to fill it.
should i try to add more? pressure has been around 35-40psi since the first time i filled it. 100+ H.I. days are killing me, but only for a few minutes at a time...
(the other) sean
'94 855 5-speed
'02 lifted Nissan XTERRA
'94 855 5-speed
Wondering if anyone can help diagnose a problem I'm having with my '95 850. It blows hot air sometimes when the a/c is on. If I turn off the a/c and wait a few minutes, it will turn cold again. Refrigerant amount & pressure is ok... could this be a problem with the compressor or condensor? Anyone know how to diagnose?
I am having the same problem as the two above. Basically put.... It seems in the morning the AC never shuts off. IT is cold enough to give you a headache. When I am driving home I notice it shuts off frequently at the same time in the same place every day. I can tell when it is happening because I can smell that OZONE smell. Then the temp starts to climb. I think it has to do with me putting a load (driving uphill) on the engine or something. All I know is that it is becoming intollerable.
Could it be overheating and shutting off temporarily?
It only does it on the warm days when it is over 85 degrees.
yeagermeister
- Year and Model:
sounds like you've been driving my car!!!!Sambryan wrote:I am having the same problem as the two above. Basically put.... It seems in the morning the AC never shuts off. IT is cold enough to give you a headache. When I am driving home I notice it shuts off frequently at the same time in the same place every day. I can tell when it is happening because I can smell that OZONE smell. Then the temp starts to climb. I think it has to do with me putting a load (driving uphill) on the engine or something. All I know is that it is becoming intollerable.
(the other) sean
'94 855 5-speed
'94 855 5-speed
- 33 Replies
- 11434 Views
- 26 Replies
- 7791 Views
Last post by MoVolvos
- 31 Replies
- 13436 Views
Last post by ToriWhite
- 13003 Views
- 11 Replies
- 19449 Views
Last post by volvolugnut
