I’ve been getting oil on top of the valve cover. Also light smoke coming out of dipstick. I’m assuming I need to replace or clean the PCV. I left the black cover off of the valve cover to monitor the oil (easy access to plugs). Plugs were recently changed and gapped accordingly. Car is running rough in low gear and check engine light is on. Misfire in cylinder 1. Cleaned oil off of the plug threads in cylinders 1, 2 and 3. Any suggestions as to what is causing my misfire in cylinder 1?
Codes:
4-5-1 Misfire Cylinder 1
5-4-3 Misfire At Least One Cylinder
5-5-1 Misfire Cylinder 1 / Three-Way Cat Damage
5-4-5 Misfire At One Cylinder / Three-Way Cat Damage
Just did Seafoam treatment today. Didn’t seem to help.
Should I clean the PCV or replace it? Trying to save money. Also, how important is it to have the black cover on over top the plugs and valve cover?
Cylinder 1 Misfire and Oil on Plugs
Johnny78Blaze
- Year and Model: 94 850 Turbo Wagon
- Year and Model: Many Volvos
- Been thanked: 76 times
The spark plug cover is more decorative than functional - you aren't hurting a thing by running without it. Have you run a compression test on the number 1 cylinder?
- Has thanked: 312 times
- Been thanked: 818 times
Agreed, you ASAP want to check compression in #1.
While the car is running, if you pull the #1 plug wire can you get it to spark to the valve cover?
Johnny78Blaze
Going to run a compression test asap. Will get back to you guys.
the oil leaking from the oil cap / that pcv vent tube / spillage from messy oil changes can get into the cyclinders and penetrate past the plugs and cut off your spark.
1998 S70 T5 SE 214,001
1999 v70R 126,000
1999 v70R 126,000
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Is the plug on #1 firing? Pull it out, leave it connected, and ground it to the block.
If the oil cap seal is leaking badly enough, a crap ton of oil can get down in the plug holes on #1 and 2 and drown the top of the spark plug in oil.
'98 S70 T5
2016 Chevy Cruze Premier
Johnny78Blaze
I know it's been awhile since I posted here but I started a new thread about PCV kit and such. Anyway, I did the kit and now getting misfires in #1 and #4 and high turbo boost pressure. Just got new compression tester today so I'll have numbers by the weekend.
When you do the compression test do all 5 cylinders. The quality and accuracy of compression gauges is pretty horrible until you get into the big dollar gauges but the consistency between all 5 cylinders will be more telling. My gauge is always at least 50 PSI lower than what I think it really is but it is a Harbor Freight compression gauge from some unheard of province in China.
If the car runs and the compression gauge says they are all running at - say 90 PSI - then we can just figure that the gauge is wrong. The important thing is the numbers between cylinders and how they match up.
Johnny78Blaze
Exactly Lee....I'll keep you updated. Thanks again.
Johnny78Blaze
I used my kit's long extension bar for the first four cylinders and used the small adapter for cylinder 5. 5 was a lot higher than the other cylinders. I remembered afterwards that I forgot to have the throttle opened all the way and redid the compression test on all 5 cylinders. Lee, with the extension bar my numbers were roughly 50-60 psi lower than with the regular adapter. So, I used the regular adapter for all 5 cylinders and got much better and seemingly accurate results (my tester is from Taiwan) all while keeping the throttle wide open. Here's what I came up with:
Cylinder 1 - 168 psi
Cylinder 2 - 175 psi
Cylinder 3 - 173 psi
Cylinder 4 - 175 psi
Cylinder 5 - 167 psi
Cranked about 10 times for each and the pressure jumped gradually. All in all I think they're not bad numbers. As far as the 'gradual' pressure jumps, I think I probably have worn piston rings. I'm sure this is now not the reason for my misfire situation. I'm going to order a fuel pressure kit and check my fuel delivery system thoroughly. Hoping it may be something as simple as a new fuel filter. Haven't changed it at all in almost 3 years. I'll update after I check the fuel system. Any other suggestions are very welcome. Thanks again.
Also, after the compression test I took it for a drive down the road, reset the CEL and drove it home. Only codes coming up are for a misfire in cylinder 4. No code for cylinder 1 or code for high turbo boost pressure. It could only just be a matter of time as well for those to pop up again.
- 16 Replies
- 4527 Views
Last post by shiloh51933
- 2956 Views
- 12 Replies
- 4618 Views
Last post by June
- 1722 Views
Last post by FLXC90
- 1268 Views
Last post by bill740
