Fuel tank lid won't stay shut
eharriett
Year and Model: 2001 S80
Post by eharriett »
Have a 2001 S80 with 235,000 miles. I filled the car up and heard a light creak when I went to open the lid for the fuel tank, and now the lid won't stay shut. It swings freely and will no longer lock when the doors lock. This has happened once before while the car was under warranty and the dealer replaced a part, but that was 8 years and over 175k miles ago. I believe he said it would be a $100+ repair, and for something that keeps happening, I'd really like to avoid an expense like that again. Does anyone have any ideas what broke and is it something I can fix for less?
Thanks
FCPEURO
Year and Model: 2006 XC90 V8
Been thanked: 19 times
Post by FCPEURO »
More then likely it is the electronic latch inside the fuel door. Going 175K miles without it breaking is very good I might add.
didmkrmra
Year and Model: 2001 S80 2.9
Post by didmkrmra »
My daughter recently brought the same issue to my attention on my 2001 S80. It sounds like the spring on the fuel door hinge is no longer connected to the black hinge (plastic tabs broke off). I found a replacement hinge locally,( and aslo on ipdusa.com) less than $10. (pic attached) It sounds like a simple procedure to remove the old hinge and replace it. There are specific directions for S80's available at ipdusa's site when viewing the part. (on the S80 you have to connect the door and spring to the new hinge BEFORE attaching it to the car)
The lock engaging the fuel door is a separate issue. There is a ~$98 solenoid that engages the door when the car is locked, mine doesn't engage instantly when the car is locked... not sure when it happens, I haven't waited long enough to find out.
I think the replacement hinge will solve your problem.
yuckuJackD
Year and Model: XC70; S80; S40
Been thanked: 2 times
Post by yuckuJackD »
yeap, i thiknk i't's the hinge, too.
I've made a manual, but it's wrote in Bulgarian...
I'll post you just the photos, hope this will help:
Good luck
A member of VolvoClub Bulgaria
Of All The Things I've Lost,
I Miss My Mind The Most.
VOLVO 440 1.7i 89y. B18E
VOLVO 460 1.8 mono 91y. B18U
VOLVO S40 1.8 115hp 16V 97y. B4184S
VOLVO S80 2.9 200hp '00y. B6294S
VOLVO XC70 D5 185hp '06y. D5244T4
pcjjjr
Post by pcjjjr »
2001 S80 288,886 miles. Mine has done the same. I purchased a kit similar to the above and it worked great for another 75,000+ miles or so. Then the spring portion broke again. Every time I took a left hand turn, the door flew open. When I start again, or go right, the door closes.
I resolved the problem by purchasing some small magnets from the Home Depot. I stacked two on the top side and two on the bottom side. The door no longer swings open as I drive or stop.
Very inexpensive fix to this problem. No, it doesn't fix it properly - but now nobody tells me that my fuel door is open.
Volvo Family
Year and Model: XC90 2004
Post by Volvo Family »
Thank you yuckojack for the detailed pictures. I was able to identify the source of my problem. I still have one question. How did you remove the fuel door? Your pictures begin after the door has been removed.
Thank you again
yuckuJackD
In these two pictures I show how I press UP (isdie to me) with tha screwdriver. This way I just brake the old clips which actualy are not needed anymore, so it's OK.
Good Luck
p.s. myne door was totaly down when broke, but it's not matter - the procedure is the same.
