svvt on 89 760 2.3 turbo has your gone out?
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
williamvomusa
Year and Model: 760sw Turbo 1989
Post by williamvomusa »
replaced all bad vacuum hoses that I could find and still can not get air to come out my dash vents could it be that my svvt is bad any one have this problem before? air is blowing thru defrost and floor vents but the dash vents will not work at all.
thank you in advance for your help.
jimmy57
Been thanked: 320 times
Post by jimmy57 »
By "svvt" I think you are talking about the electric solenoid valve bank under climate case on RH side.
There is a pin on the circuit board that is prone to getting solder joint crack and it takes down all the solenoids.
If it has a floor /defrost and recirc vacuum servos leaking and the system is in recirc the same symptom occurs.
One leaking gives changeover on acceleration and hills but when recirc is active (in Austin this week it will be...) you could easily have two leakers dumping all the vaccum.
williamvomusa
can the pin on the circuit board be fixed?
jimmy57
Post by jimmy57 »
Yes, Soldering iron and a little rosin core solder. When you take it out of car and turn it over the solder joints are accessible on the bottom.
williamvomusa
Thank you very much. I am in the process of looking for a engine shop to do a head job in the Dallas area we just moved to Canton, TX
williamvomusa
We inspected and test it and found almost all of them needing to be soldered. Will have it done tomorrow. Thank you for your help.
williamvomusa
Was able to get it soldered today and back in and the A/C is blowing thru the dash vents! thank you for your help I now think its time to put a new puley on it i hear the loudest squel while the A/c is turned on and I start the engine. Thank you again.
