No more warning lights on my '99 S70!
trackminer
- Year and Model: 1999 S70, 1986 244
Just thought I'd post this pic as a testament to this forum!
Reason: Lowercased title.
...pullin' off slow - in a VOLVO...
Chris Bowsman
- Year and Model: V70 XC AWD 2000
Wow... mine has like 4 of them on all the time
trackminer
Here is a list of things I did:
1. Changed out 2 ignition coils
2. Replaced Evap Purge solenoid
3. Disassembled and repaired the ABS module(cleared up most of my issues)
4. Cleaned the throttle body
5. Replaced spark plugs
6. Replaced all visible rubber vacuum lines
7. Cleaned up and repaired any broken or cracked evap lines using "self amalgamating" tape
If you are having issues with the ABS/Brake light problem that these cars are known for, inspect your suspension...bad front struts will put some serious stress on the ABS module...
If you don't have access to a code scanner, check with your local Autozone or Advance Auto Parts, they'll check it for free...
-Trackminer
-Trackminer
trackminer
The tape that I used is similar to this:
trackminer
Hat cam! LOL!
- Year and Model: Many Volvos
- Been thanked: 76 times
You can buy a basic code reader for around $40.00 USD, with your Loonies it should be even cheaper. It won't do all of the fancy real time monitoring but it will read and reset power train codes.LamboSE5 wrote:Hey - Congrats man, must feel great!
-Have an Autozone equivalent for Canada? Hahaha
I'm looking at about 70-100 to get codes read...not funny
trackminer
thanks for your support Mr. Lee!
- 1447 Views
Last post by s10lowrider1994
- 3565 Views
Last post by BEJinFbk
- 15 Replies
- 6615 Views
Last post by neworleans
- 1978 Views
- 15 Replies
- 4327 Views
Last post by Eastema
