hi yall
96 volvo 850 turbo wagon
My a/c works good most of the time as long as the onboard outside thermometer doesnt go above the mid 90's. once the temps do get over the mid 90's the a/c will intermittently fail. everything will be fine until you stop moving, it will work while stopped but once you start moving again the system starts blowing warm air and smells a little musty. if you turn the switch for the system on and off several times the a/c will suddenly blow cold again. when the temps outside are under the mid 90's the a/c blows cold enough where you have to turn it down after a few minutes of use. any ideas would be appreciated.
thanks
Adam T
intermittent a/c failure
vjaneczko
- Year and Model: 2006 S60R
- Been thanked: 7 times
Check the gap on your compressor clutch.
Read the two posts provided by Lee which you can find here:
https://www.matthewsvolvosite.com/forums ... 9&start=24
1997 855 GLT - R.I.P.
2006 S60R - For ME!
2006 S60R - For ME!
landyacht33
- Year and Model:
ok thanks ill tackle this next
- 2132 Views
Last post by BrickBetty
- 1101 Views
Last post by hiroshima1320
- 2243 Views
Last post by PS78
- 1689 Views
Last post by Clemens
- 13 Replies
- 12525 Views
Last post by Yak
