ok so, i'm not too car savvy.
But I recently had a crack in my thermostat housing that was leaking a small amount of coolant, had that replaced.
Now however when I run my car all the coolant leaves the resevoir tank, and doesn't go back in unless I remove the cap, as a result my low coolant light comes on. I have also replaced my coolant resevoir cap as the gasket was beginning to flake a bit.
Anyone know what may be the cause of this?!?!?!
thanks in advance
Low Coolant light?
Something in the collant system is expanding, most likley the radiator hoses. How do you know the coolant leaves the expansion tank?
Current Stable.
99 V70 XC
95 850T
91 240
Previous
76 242 Stick
76 245 Stick
78 244 Stick
83 760 Auto
85 240 W Stick
87 240 Stick
99 V70 XC
95 850T
91 240
Previous
76 242 Stick
76 245 Stick
78 244 Stick
83 760 Auto
85 240 W Stick
87 240 Stick
Check your drive belts for wear/loose, spray belt dressing on the belts then, gun the motor in neutral squeak should disappear.
Current Stable.
99 V70 XC
95 850T
91 240
Previous
76 242 Stick
76 245 Stick
78 244 Stick
83 760 Auto
85 240 W Stick
87 240 Stick
99 V70 XC
95 850T
91 240
Previous
76 242 Stick
76 245 Stick
78 244 Stick
83 760 Auto
85 240 W Stick
87 240 Stick
- 4078 Views
Last post by MathalomuleM31
- 1439 Views
Last post by balabaika
- 48766 Views
Last post by ggleavitt
- 2572 Views
Last post by prwood
- 13 Replies
- 7373 Views
Last post by Ozark Lee
