My washer sprayer is plugged, I know I have fluid to the tire well becuase the preasure made the hose pop off and spill fluid.
How do I remove the rear washer sprayer to replace or repair it ?
rear washer sprayer plugged 94 850 wagon
mrjacobrussell
- Year and Model: 2006 s60R
- Has thanked: 2 times
2004 S60R AutoX Car
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
2005 v50 t5 AWD for sale
I have a Chinese DICE, works well.
In southern Oregon.
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
In southern Oregon.
mrjacobrussell
I coulndt find it in the forums search feature. So I search google after I made this post and google reffered me back to the forum, and this info. I'll take it all apart this weekend and see if i can get this marked off the list
https://www.matthewsvolvosite.com/forums ... php?id=362 vadis washer pdf
https://www.matthewsvolvosite.com/forums ... 5&p=119151
https://www.matthewsvolvosite.com/forums ... =1&t=32247
2004 S60R AutoX Car
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
In southern Oregon.
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
In southern Oregon.
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
I use Google too. I type in (for example) "rear windshield spray site:matthewsvolvosite.com" into the Google search box and it works pretty well.
I had the same problem with the windshield spray at the rear window on my '97 and once I removed the upper trim and removed the check valve near the nozzle, all was well.
Good luck!
Good luck!
Red-Arrow
- Year and Model: 850 T5 1995
- Been thanked: 2 times
There is a small black check valve, not the large clear filter that picks up junk. This black CV is behind the rear tail lamps. This will be your problem. It was on mines. I just removed the valve and used a pipe in its place. Cost zero.
Life would be enjoyable if it wasn't so painful to live.
- 734 Views
Last post by cvtech
- 1343 Views
Last post by Richard99
- 1063 Views
Last post by mickjenkins
- 1815 Views
Last post by mrbrian200
- 893 Views
Last post by cn90
