Oil Leak '98 V70 XC
dimesfromheaven
- Year and Model: 1998 V70xc
I'm trying to diagnose where my oil leak is coming from on my '98 XC. I've had the oil cooler lines replaced, which I knew were leaking but it's still leaking pretty badly from somewhere else. I'm losing about a quart every week and a half. Anyway, it seems to be coming from the passenger side of the car as there is a lot of gunk coating the suspension parts on that side. Any help with where I should start or what to look for would be much appreciated.
It might be worth checking to make sure the cooler lines were installed properly and the O rings at the ends of those are good. When I installed my cooler lines the first time, I accidentally cut one of the small O rings during installation and had to do it over again. The fact that your leak is on the passenger side is suspicious because that's where the cooler lines are.
1998 Volvo V70 AWD 165000-R muffler, HD endlinks, boost gauge
2008 Ford Fusion AWD 107000
2000 Ford Ranger 4wd 172000
1991 Toyota Camry 160000#1
Previous: 1982 Volvo DL (240) 160000
1998 Tacoma, Fords (6), Dodge, Montero,
GTO, Sunbeam Alpine, VW Dasher
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
I'd pull off the timing belt cover and have a look around there as well. The top part will enable you to peer down in there. Leaky cam seals, depending how bad they are, can leak oil out quite quickly and fling it towards the rear of the engine.
'98 S70 T5
2016 Chevy Cruze Premier
dimesfromheaven
Thanks a lot guys. I'll have a look and see what I find.
- 3866 Views
Last post by FlyingVolvo
- 64 Replies
- 25653 Views
Last post by prwood
- 811 Views
Last post by Grover365
- 1435 Views
Last post by t3yf5g
- 1309 Views
Last post by Vovo_merz
