ETM plate position
edbrig
Year and Model: 2000 Volvo xc70
Post by edbrig »
I recently removed the ETM for replacement but am considering trying to clean it before I spend the 600 bucks on an XeModex refurb. The plate inside the ETM stays open ever so slightly. Is this normal or should it close 100%? Is it worth cleaning or should I just get a new one from XeModex?
Any help would be greatly appreciated
Ed
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
How did you go with the suspected ETM failure. The throttle plate's normal operating angle is between 24 and 33 degrees on the ETMs I've tested so far, so it's quite a noticable gap when you look at it.
Hope this helps
Sent from my GT-I9100T using Tapatalk 2
