My '91 240 with retrofitted a/c hasn't blown cool air in years. I found that the a/c hose between the compressor and drier was worn through so I replaced that, filled with new refrigerant/oil, only to find that it still wouldn't work.
I ran the compressor clutch sire directly to the battery and the clutch engaged. I started the motor, re-attached the compressor wire to the battery and all i get is a grinding sound, presumably from between the clutch plates.
So I need to diagnose the reason why the interior switch won't work, and diagnose the non-functioning compressor.
Any thoughts/advice?
'91 240 a/c clutch won't engage
- 826 Views
Last post by doublebug
- 814 Views
Last post by skippy
- 19 Replies
- 8615 Views
Last post by Roger_850T
- 952 Views
Last post by kaneelschep
- 1780 Views
Last post by MyS40T4
