Guys I'm back in Scotland and need a Volvo of course. The problem is with Gas costing $9 a gallon I ain't touching a 2.3 Turbo petrol car with a very long pole attached to a very long pole. I need a diesel.
Now I am not intending to run it on diesel either as I know people use veggie oil. some filtration and acetone is all that needed right? Anybody ahead of me have any advice?
Who owns a Diesel and runs it on veggie oil?
Marcobrick
- Year and Model: 2003 V70T5
- Has thanked: 3 times
You need to take the glycerides out of it too which requires "washing" with potassium hydroxide or sodium hydroxide. Do some googling there are some good guides out there.
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
1973 Land Rover Series 3 flat deck.
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1995 850 Turbo Wagon
1998 V70T5
Favourite line: "How hard can it be?"
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1998 V70T5
Tall Grille
- Year and Model: 1998 V70 GLT
Washing vegetable oil is part of the process of making Bio-Diesel. You can run straight Waste Vegetable Oil. I have successfully run WVO in multiple diesels (never a Volvo). You will need to filter it. I generally stretch a piece of cloth over a five gallon bucket and pour it in to pre-filter all of the large chunks of potato/chicken out. Then I filter it twice through coffee filters. You can get away with running straight WVO as long as your temperatures don't drop too low. You will be better off running a 50/50 mix of WVO and Diesel or running a seperate heated tank for the WVO so you can start on diesel till the coolant warms up the WVO, you will need to switch back to Diesel a few miles before shutting the car down to purge the lines so the oil doesn't thicken in the fuel lines/filter. Check out www.greasecar.com There is a lot of info online for DIY grease kits also.
