My 2004 xc 90 has the front calipers locked....i just replaced the rotors and pads and calipers. When put in gear car wouldnt move and in slopes it would slow down.
Need help, second set of calipers put on and same thing..
ABS not working properly, will not activate when braking over wet surfaces.
My xc90 will not move....
goldfishhh
- Year and Model: 2006 XC90
Replaced the Calipers at 7yrs? Odd. Did you have a failure or did they look "yucky"?
I'm pretty sure you have an air bubble somewhere in the system. I'd do a complete brake bleed again, making sure there is enough fluid in the reservoir not to run it empty.
voltech1
- Year and Model: 2000 V70R
- Has thanked: 2 times
Quick guess it is the E-brake shoes. I don't think air in the system would cause anything but soft pedal (air is compressable). Any shop can bleed these systems but not the problem. Can you lock-up the brakes on ANY surface? The E-brake shoes fall apart and get wedged inside the rear rotors.
96 855 turbo 235k
00' v70r 156k w/blown motor
- 1873 Views
Last post by cn90
- 829 Views
Last post by rspi
- 1363 Views
- 520 Views
Last post by Joshg
- 1289 Views
Last post by wizechatmgr
