MAF Trouble
Buffalo Surfer
- Year and Model: 850 1995
Started having problems with some rough idling, sluggish take offs with occasional stalls. I had just changed the sparks and wires so I went to the auto parts to hook up to the diagnostic and had the MAF Po133 and Cat P0103 come up. I went ahead and bought one rebuilt MAF and installed it and the car run a lot faster but at idle it went crazy and was very jumpy accelerating and constantly adjusting with no settling after 5 minutes. So I went ahead and put the old MAF on and changed the sparks again and my neighbor who races cars and is well versed in mechanics came over to look at the car and noticed that in the air box intake the is a vacuum operated valve(located in the Y intake on the lower end of the air box )for the air flow intake and he suggested to open that valve to allow the air to flow freely so I was able to hold it open permanently with a large screw and when I started the engine it did wonders and eliminated all stalled take offs but I still get some rough idling. The car now starts and it adjusts quickly and runs good when moving but is a little irregular when idling. I wonder if this can continue or I have to find the real problem to the sickness ailing my volvo. I can afford a mechanic so I have to try to resolve this matter alone. Can anyone help me please?
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Yank off the negative battery cable, touch the brake pedal a few times, and then reconnect it. This will let the engine re-set its adaptive from running with a futzed-up fuel trim table. Give it a few days or trips to let it even out, and let us know if it runs any better or worse once it gets used to this "new" setup.
'98 S70 T5
2016 Chevy Cruze Premier
jblackburn
Oh, and make sure you've got your radio code first.
'98 S70 T5
Buffalo Surfer
THANKS AGAIN JBLACKBURN, I DID BUY A NEW BATTERY NOT TO LONG AGO......AND MY WIFE OVER FILLED THE OIL A LITTLE1/2 QUART WORTH......I'LL TRY THE ADVISE WILL LET YOU KNOW HOW IT WORKS. tHANKS
Buffalo Surfer
Hey Jack, I tried your advise but it has not changed the problem at all. Any other advise?
- 1969 Views
Last post by albertoVO5
- 26 Replies
- 6782 Views
Last post by ChadLee
- 3201 Views
Last post by itsmekirby
- 11 Replies
- 4880 Views
Last post by matthew1
- 1185 Views
Last post by neworleans
