I got an issue with my 2002 Volvo S60 2.4T, 116,500 miles.
When I made a brake, I need to step the pedal down 30% deep, then the brake start to work, and then I can easily push the pedal down to the floor.
The brake can still work but several mechanics told me to replace the brake master cylinder. So I replaced it yesterday and filled new fluid.
After repair, I feel only a little change on my brake pedal. It still can be push down to the floor (a little bit harder than before). The brake will start working after push it 15% deep (instead of 30%).
I think there might be another problem in my brake system. Anyone met before?
Why Brake pedal goes deep?
BrendanM
- Year and Model: V70 T5, 2000
I have a similar problem which I am trying to solve today. The pedal travel has got steadily worse over the month. I also suffer from the no brakes at first start in the morning syndrome. I am nearly at the floor now and braking power is not good. I am not using any brake fluid - not topped up in a few years. Pumping brakes makes no difference to the travel. Booster is working becasue if I hold brakes then start the car then the pedal travels further down. It cannot be the master cyclinder seals since surely I would be losing fluid?
Today I will try and flush out all the old fluid since it has been many years since that was done.
dongwenxuan - when you put in your new master cyclinder and bled - did you flush out all the fluid to each wheel or did you just top up?
BrendanM
OK some feedback. I sucked out all the old brake fluid from the MC tank. Then filled with new fluid and bled at each wheel until new fluid came out. Kept topping up with new fluid. Order was rear right, rear left, front right, front left. My old fluid was really old & brown. I also seemed to purge some air when bleeding the rear left so that was probably also not helping. Brakes are nice and hard now on the first press. Pedal travel is back to normal.
Fish stick88
- Year and Model: 1994 - 850 Sedan
Thats why i would suggest. If you were having problems before, the air may have been the factor that made it have no pressure, after changing my calipers, i had to do the same, Also.. Did you bleed the lines too when you changed fluid?
Speed has never killed anyone, suddenly becoming stationary... That's what gets you.
'94 850 Sedan - 160k miles
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
Low pedal can be caused by many things. If a full bleed of the whole system doesn't resolve the problem then there are some things that I am curious about.
Have the brake calipers been removed and the outboard springs not re-fitted correctly?
Are any of the wheel bearings faulty and loose?
dongwenxuan
- Year and Model: S60, 2002
Update. I did a brake fluid flush in dealership and they only charge $75 and applied a 20% off coupon. The pedal won't go down to the floor anymore after this job done. But the brake will only start working after push it 5% deeper compare to a new car. Problem almost resolved.
vjaneczko
- Year and Model: 2006 S60R
- Been thanked: 7 times
When they flushed the system, did they re-install the same rotors & pads or replace them? That may be the final piece to the puzzle.
1997 855 GLT - R.I.P.
2006 S60R - For ME!
2006 S60R - For ME!
dongwenxuan
That make sense. The dealer didn't replace the rotors and pads. I'll replace both of them before next brake fluid flush and we will see.
vjaneczko wrote:When they flushed the system, did they re-install the same rotors & pads or replace them? That may be the final piece to the puzzle.
- 2654 Views
Last post by jonesg
- 3266 Views
Last post by volvo240student
- 1529 Views
Last post by dosbricks
- 12 Replies
- 5194 Views
Last post by bmdubya1198
- 786 Views
Last post by Randall0208
