Broken exhaust
shakamambutu
Year and Model: 1994 volvo 850 2.4
Post by shakamambutu »
hi my exhaust is broken!! where can i get a new exhaust, performance or the stock suitcase one. please help soon!!!
Reason: "Help" is not a helpful title. Please read the forum rules.
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
Where is it broken exactly? Many pieces of the exhaust pipes can be welded back together by a good shop.
If you can get under the car and snap a picture of where it is, someone here can probably tell you whether or not it can be repaired.
'98 S70 T5
2016 Chevy Cruze Premier
vjaneczko
Year and Model: 2006 S60R
Been thanked: 7 times
Post by vjaneczko »
+1
I had my cat rust out right at the rear seam and the joint at the clamp in the middle of the car. Midas patched them both for about 80 bucks each. For the cat, they shoved a pipe inside the factory pipe for additional support then welded it all together.
If it's the flex pipe coming off the mani, you can search eBay for people selling them. Just make sure you figure out if you need the straight or angled version.
If you want to replace the whole thing, take a look at IPD's stainless steel setup. For a grand, you'll get a thing of beauty, be able to install it yourself and it includes a cat. You can also take a look at OBX's offering - much less $$ but doesn't have a cat and you need a shop to install it.
1997 855 GLT - R.I.P.
2006 S60R - For ME!
