I need front brakes for my 95-850NA. FCP Groton has, like 4 different ones... I just want the car to stop, without squealing...what do you all recommend?
I also need wiper arms...they have Scan Tech. Does it matter? Should I buy Volvo?
Need front brakes...
I've heard bad things about scantech. For the wiper arms, I would find a pair from an S/V70 that you can take. Those don't get bent out of shape.
1988 240 DL (Clarisse) 136K- Sold, but close by
1994 850 Turbo Wagon (Tula) 202K-RIP
1997 850 T-5 Wagon (Greta) 135K
1997 960 Sedan (Linda) 169K
1998 V70R Saffron (Thor) 160K
You mean...find a junk yard for the arms? Wouldn't those be just as 'worn out'? My splines are shot...the spring is shot.IceTurbo wrote:I've heard bad things about scantech. For the wiper arms, I would find a pair from an S/V70 that you can take. Those don't get bent out of shape.
Juan62
- Year and Model: S70 T-5M 1998
- Been thanked: 2 times
Alan,
Search the IPD ad above...this will help more on your selection (correct part numbers). That said, only if your brakes are still factory (rotors). The reason I say this is for an example; Big Brakes (big rotors) will not allow the Volvo pads to fit.
Here are some more: the three ads above this forum plus, partsgeek.com, buybrakes.com, brakewarehouse.com
Rotors any good? Inspect them too.
98 S70 T5-M Brick for life
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Here are the responses I got when I asked the same question:
https://www.matthewsvolvosite.com/forums ... =1&t=32683
Do your current brakes shake the steering wheel AT ALL when you apply them? If so, you need new rotors as well - that shaking will only get worse.
FWIW, still very happy with my Akebono/Zimmerman combination. 27,000 miles on em
'98 S70 T5
2016 Chevy Cruze Premier
- 5803 Views
Last post by vtl
- 2147 Views
Last post by oragex
- 889 Views
Last post by photoguy
- 558 Views
- 1075 Views
Last post by radchadtke
