Hi guys, I have Foour questions.
1. I need a new spark plug cover. Months ago I ran across one looking for other parts. Now that I need it, I can't find it again. does any one know where I can find one?
2. I need to replace the rear view mirror. Does any one know the trick to popping off the trim panel covering the mount? I haven't pulled the interior light lenses yet thinking maybe there are some screws under them. The plastic is old and I do not want to break any tabs.
3. I am still looking for good fitting seat covers for the front seats. any one have a good source?
4. I need a source for the head lamp connectors are baked and one has fallen apart. The spades ae also cooked and the amps are damaging the spade on the bulb.
I now have this thing running great after replacing the troutle body with the one from the Canadian company, The entire PVC system, Most of the hoses, Timing belt with all parts, starter, drive belt with tensioner and plugs, at first I was pulling my hair out. I got a bad spark plug broken down below the metal base. After thinking it was the coil which didn't help, I went to change the plug having the entire top come off with the coil.
help to find a source for a spark plug cover 99 S70 Turbo
Juan62
- Year and Model: S70 T-5M 1998
- Been thanked: 2 times
Go to; www.oemvolvoparts.com
put in your year and model, under engine, cylinder head and valves, item #4 is your (spark plug) cover.
98 S70 T5-M Brick for life
JRL
- Year and Model: Several
- Been thanked: 16 times
www.erievovo.com for used
1888 volvo 13
1888 volvo 13
- 3128 Views
Last post by Roger_850T
- 1298 Views
- 25 Replies
- 4527 Views
Last post by xHeart
- 24 Replies
- 2460 Views
Last post by JRev
- 3941 Views
