I replaced two ground straps (both are corroded and one of them even snapped in half) linked between top of the engine and the firewall/frame. I wonder if there are other straps to check in the engine bay ?
Also, I see the negative battery cable have 2 wires, 1 tied to the frame near the battery frame and another assumed to be tied to the engine or transmission casing. Is there more ?
I wanted to work all this so the electrical system is in top shape after living thru a bad starter, bad battery, bad B+ cable and bad alternator in a few weeks span.
Grounding system check
- Year and Model: Many Volvos
- Been thanked: 76 times
As far as the main grounds go you have them covered. There are dozens of other ground points for individual items throughout the car though.
