C70 center speaker question
c70_lindsay
- Year and Model: 99 S70 T5.
I have a 2000 C70 with the 11speaker dynaudio setup. The center speaker on the dash makes a rattling noise as though something in the way it is mounted has loosened up(not a blown speaker noise). I do not know how to remove the speaker to check in out and snug everything up, does anybody know anything about this. Thanks.
JRL
- Year and Model: Several
- Been thanked: 16 times
Carefully pry up the corners of the speaker cover, it will unsnap
You will then see the speaker, 2 screws and out she comes!
Probably shot, these are very fragile, shallow and fail quite often
c70_lindsay
Thanks but not quite sure what you meant by "these are very fragile" the screws or the speaker?
JRL
Speaker is junk
You may go through 2 or 3 during the car's lifetime.
Sitting up there in the hot sun, the magnets just fall out
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
That's why the later, "revised" version has a bolt through the magnet.
If you find that is does need replacement, it's PN: 8622157.
fazool
- Year and Model: S60, 2007
- Been thanked: 7 times
I upgraded by purchasing a single speaker from clearance (open box). Check Sonic Electronics and Crutchfield. I found an open box component speaker system with one missing piece. I got an excellent since 6.5" mid range speaker (with a crossover and a separate tweeter).
You could buy a Pioneer or Sony 3/4 way 6.5" speaker pair at Walmart and be *WAY* ahead in quality. If you shop the clearance areas you can sometimes find a single speaker, like I did.
2007 S60 2.5T AWD (Daily Driver)
2001 S60 2.4T (Daughter's Car)
2003 S80 2.9 (Son's Car)
1995 850 2.4 (Daughter's Car - sold off)
2005 S40 2.4i (Bought new - since sold)
1986 740GLE 2.3(First Volvo - sold off)
- BEJinFbk
I'm guessing you've never had the center channel out of the dashfazool wrote:I upgraded by purchasing a single speaker from clearance (open box). Check Sonic Electronics and Crutchfield. I found an open box component speaker system with one missing piece. I got an excellent since 6.5" mid range speaker (with a crossover and a separate tweeter).
in one of these older ('98-'00) Volvos equipped with Dolby Surround.
If you're driving a Gen 1, there are severe depth restrictions.
You'll find yourself directly on top of the center vent ducts.
The OEM center is an inverted magnet/voice coil speaker.
Pretty rare speaker with a very shallow backside.
The OEM is virtually the only game in town...
JRL
We said this, he did not listen
fazool
Ahhh, yes, sorry I was relating to my experiences with the 01-07 P2's where its a little deeper
- 12 Replies
- 2655 Views
Last post by E Showell
- 899 Views
Last post by Synthguy
- 11 Replies
- 3991 Views
Last post by JRL
- 5515 Views
Last post by BEJinFbk
- 720 Views
Last post by gordo850turbo
