86 740 hit bump = loss of power
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
e777
Year and Model: 1990 740
Has thanked: 11 times
Post by e777 »
Hello,
My 86 740 NT wagon has been doing something odd lately. I'll be driving at about 35mph and then occasionally, when I hid a bump in the road, I feel a sudden loss of power at which time I have observed the tach to suddenly drop to 0 before jumping right back to normal. The car has all new-ish ignition components, with the exception of the coil. Could this be ECU related?
Thanks,
Eric
Wagons:
93 940
91 240
90 740
86 740
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
Check the condition of the red wires connecting to the positive battery terminal.
1988 Volvo 760 Turbo Wagon
e777
Post by e777 »
Thank you. I will check it out and let you know what happens.
Wagons:
93 940
91 240
90 740
86 740
jimmy57
Been thanked: 320 times
Post by jimmy57 »
Check the power stage (coil signal amplifier) connector on left fender behind and below the back of left headlamp.
e777
Post by e777 »
Thanks, jimmy 57. I checked the power stage and it was secure (although I probably should clean the connectors). What I did find, as our colleague suggested, was that the two bolts holding the positive battery cable to the connector clamp were quite loose. I tightened them and will see what happens. Thanks again to the both of you!
--Eric
Wagons:
93 940
91 240
90 740
86 740
