clock spring?
clock spring?
i have a 2001 v70 and recently replaced the rack & pinion. now, the steering wheel controls don't work and the SRS airbag light came on in the dash. from what i've been reading on the net it seems like it might be a clock spring that needs replaced?? does this seem right?
jimmy57
- Been thanked: 320 times
Sounds right. If the steering wheel is not controlled when steering gear is removed from the shaft then the steering wheel can easily be turned and when you re-connect the steering gear you can turn wheel and go past the limits of the contact reel (clock spring).
On airbag cars this is prevented by tying a rope around one of the spokes and securing the other end of the rope to the gear lever or around door frame. Rope should be short enough to keep from going more than a half round.
You can lock the steering by removing the key but that results in the wheel being locked where the bolt is not accessible most of the time.
JRL
- Year and Model: Several
- Been thanked: 16 times
Who installed the rack?
I ask because it's a 95% chance that that person broke the clock spring trying to reinstall the column
