VERY BAD PROBLEM
SniperC4007
Post by SniperC4007 »
VERY BAD PROBLEM HERE!!!!
My automatic transmission...
D, 3, 2, 1 respond as if it were N, R works fine, i think
I accidentally overreved my engine, well it was right before the red and then i switched to D and thats when things started to get out of whack
I had a fat cd case on the floor and it kinda got between my foot the the acceleraot which cause the high rev... Just for you info.
WHAT DO I DO!?
Sniper>>
________________
1986 Toyota Corolla SR5
1986 Volvo 740 GLE
1989 BMW 535i
Guest
Post by Guest »
Can anyone tell me what could of happened?!?
Kmaniac in California USA
Post by Kmaniac in California USA »
I am not that familiar with Volvo automatic transmissions and my repair manual does not go into detail about the inner workings of such. However, I am much more familiar with the operation of the Torqueflite automatic transmission in older Chryslers. For a Torqueflite, the symtoms you describe (working reverse and no forward gears) are indicative of a non-engaging rear planetary gear clutch pack. Since most modern automatic transmissions use planetary gear sets with clutch packs, I would suspect one of your clutch packs has malfunctioned and is no longer locking the planetary gear set needed for forward movement. I think it is time to call the Transmission Shop on this one.
Chris the "K MANIAC"
1986 740 GLE
(5) 1964 Chrysler 300-K's
SniperC4007
Yeah, thats what im going to do on Monday, any idea how much it may cost?
Sniper>>
________________
1986 Volvo 740 GLE
1989 BMW 535i
SniperC4007
Just to give you guys some info, a pump bursted or failed causing the transmission to not be able to shift to the forward gears. Everything has been straightened out
Sniper>>
________________
1986 Volvo 740 GLE
1989 BMW 535i
