Some quick questions:
1. What does it do?
2. How does it work?
3. What are the symptoms of failure and how do I test it?
I am losing fuel pressure when shut down and before I go removing the fuel tank to get to the regulator, I want to be sure to check everything else first.
Fuel Pulse Damper
- misha
- Has thanked: 155 times
- Been thanked: 432 times
This should answer all of your questions:
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
It could be a bad check valve.The bad news are that it's the part of the fuel pump.In other words,it's integrated in the pump.ajr2820 wrote:...I am losing fuel pressure when shut down and before I go removing the fuel tank to get to the regulator, I want to be sure to check everything else first.
Solutions are to simply add a check valve in fuel line or to replace fuel pump.
One other thing that might help would be priming before starting the engine.
Priming:
Turn the key to ignition II.You should hear the fuel pump running for about 2 seconds.When it stops,immediatelly turn the key off and back again to position II.Repeat this procedure 3-4 times before you start the car.On 4th prime,start the car immidiatelly after the fuel pump stops.
This builds the pressure in the fuel rail and the car starts quicker with less cranking.
If this priming helps with starting(usually does),than you will know for sure that your check valve is bad.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
Enjoy!FCPGroton wrote:Thanks for the PDF. Learned something new today.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Thanks for the responses. I did not consider putting an inline check valve on the car. That may be the best route for me as the pump still works and is a PITA to replace. Anyone know where I can get one that will suit my needs?
1999 Volvo V70-XC
200,000+ miles
1999 Volvo V70-XC
200,000+ miles
On another note. Is it possible for this damper to cause the loss of fuel pressure I am experiencing? Just want to be sure before I move forward.
1999 Volvo V70-XC
200,000+ miles
1999 Volvo V70-XC
200,000+ miles
- misha
My understanding is that when fuel pressure damper/regulator fails,the car runs very rich.
Do you have problems ONLY when starting the car or you have problems when you driving the car?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 53 Replies
- 4796 Views
Last post by dalel
- 15 Replies
- 7195 Views
Last post by WarbirdPilot91
- 16 Replies
- 3292 Views
Last post by precopster
- 20 Replies
- 6264 Views
Last post by oragex
- 506 Views
Last post by aharres
