Pic of diagram for VOLVO 960 wires from back of engine
Does anyonce have picture or wiring diagram for wires that are from the back of engine. Just replace Cyc head. I have a harness that has 3 wires I have 2 of the 3 . Not sure if 3rd one was ever there. 1996 960.
Juan62
- Year and Model: S70 T-5M 1998
- Been thanked: 2 times
Start on page 11 & 12, for 960 models.
hd14824.pdf- (717.96 KiB) Downloaded 465 times
98 S70 T5-M Brick for life
At the rear of the head you have a D shaped connector for the coolant temp sensor, a three wire plug for the cam sensor, a two wire connector for the rpm sensor, and a red/white ignition test lead that is a single female wire.
Because all of the connectors are unique, none can be mis-used.
DanR '94 964 360,000 miles (126,000 miles on the new engine)
- 1538 Views
Last post by erikv11
- 2095 Views
Last post by legalstuff
