96 850 NA AT Serious Lack ofPower.
The more I push the pedal the less power I get. With a very light throttle 0 to 40 MPH is 12 seconds. With full throttle 0 to 40 is 37 seconds. In first gear it will not go above 3400 RPM in second gear it's 3000 RPM. On the highway it won't go past 65 and sometimes only 60 and it takes 2+ miles to get up to 60. Will not go up steep hills. No codes. Performance is the same with MAF disconnected. Have replaced air hose between filter housing and throttle body. Fuel pressure is to specs under all conditions. Replaced TPS.
waynej
99 S70
96 854
87 245 wife's car
94 850 sons car
94 850 2nd sons car
Previous Volvos
93 850
87 744
85 244
82 244
80 244
78 244
78 245
76 265
71 P1800
71 142
99 S70
96 854
87 245 wife's car
94 850 sons car
94 850 2nd sons car
Previous Volvos
93 850
87 744
85 244
82 244
80 244
78 244
78 245
76 265
71 P1800
71 142
Thanks, but I already have. My post says "fuel pressure to specs under all conditions". When it peaks out at 3400 RPM fuel pressure is still holding steady at 43 PSI. at the fuel rail.
waynej
99 S70
96 854
87 245 wife's car
94 850 sons car
94 850 2nd sons car
Previous Volvos
93 850
87 744
85 244
82 244
80 244
78 244
78 245
76 265
71 P1800
71 142
99 S70
96 854
87 245 wife's car
94 850 sons car
94 850 2nd sons car
Previous Volvos
93 850
87 744
85 244
82 244
80 244
78 244
78 245
76 265
71 P1800
71 142
I don't know. I posted here hoping I could get an answer. If there is a rev limiter built into the ECU I would think it would be above 6500 RPM.
waynej
99 S70
96 854
87 245 wife's car
94 850 sons car
94 850 2nd sons car
Previous Volvos
93 850
87 744
85 244
82 244
80 244
78 244
78 245
76 265
71 P1800
71 142
99 S70
96 854
87 245 wife's car
94 850 sons car
94 850 2nd sons car
Previous Volvos
93 850
87 744
85 244
82 244
80 244
78 244
78 245
76 265
71 P1800
71 142
I agree. You said you have no codes, are you sure your CEL light is working? Haha. I really can't believe you haven't gotten a code thrown. Crazy. I will think some more tonight and see if I can think of something.
tjts1
- Year and Model: 96 855 NA 5 speed
- Been thanked: 4 times
Theres your problem.waynej wrote:The more I push the pedal the less power I get. With a very light throttle 0 to 40 MPH is 12 seconds. With full throttle 0 to 40 is 37 seconds. In first gear it will not go above 3400 RPM in second gear it's 3000 RPM. On the highway it won't go past 65 and sometimes only 60 and it takes 2+ miles to get up to 60. Will not go up steep hills. No codes. Performance is the same with MAF disconnected. Have replaced air hose between filter housing and throttle body. Fuel pressure is to specs under all conditions. Replaced TPS.
Ambitious but rubbish
confused_al
- Year and Model: 1996 TLA wagon
If your airbox t-stat failed, it will feel that way since your motor gets very little fresh air...waynej wrote:The more I push the pedal the less power I get.
https://www.matthewsvolvosite.com/forums ... f=1&t=8830
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
dbeckwith
- Year and Model: 95 850 GLT
Had this problem with mine. Felt like I was pulling an anchor. Big difference after I fixed the problem.confused_al wrote:If your airbox t-stat failed, it will feel that way since your motor gets very little fresh air...waynej wrote:The more I push the pedal the less power I get.
Git Er Done
dbeckwith
264,000 miles
dbeckwith
264,000 miles
My CEL light is burned out but I have the scan tool with me and check for codes everyday until this gets fixed. The code system is working, I get a code when I unplug the MAF. The air box heat has been disabled for a long time. When it is bad it will only produce a 20% reduction in power- I have at least an 80% reduction.
tjts1, I don't understand. I have read many posts on this forum that say the way to check a MAF is to unplug it and see if things get better. I tried unplugging the MAF on my sons 94 850 and only got a modest decrease in performance. I have an extreme loss of performance.
I just did another test. It seems like the car runs better the first minute or two after starting. I parked it outside and let it get cold then started it and revved in park. Went easily to 4000 and could have done more. After running for 2 minutes it will only do 3500.
waynej
99 S70
96 854
87 245 wife's car
94 850 sons car
94 850 2nd sons car
Previous Volvos
93 850
87 744
85 244
82 244
80 244
78 244
78 245
76 265
71 P1800
71 142
99 S70
96 854
87 245 wife's car
94 850 sons car
94 850 2nd sons car
Previous Volvos
93 850
87 744
85 244
82 244
80 244
78 244
78 245
76 265
71 P1800
71 142
- 68 Replies
- 11440 Views
Last post by 1ezliving4ume
- 1190 Views
Last post by juggernaught_666
- 313 Views
- 1556 Views
Last post by 93Regina
- 87 Replies
- 30059 Views
Last post by xydki
