Front Suspension Rattle
I have a 2001 V70 T5 165k. In the last 10 months I have replaced drive axles, lower control arms w/bushings, and front lower engine mount. I still have a suspension rattle that seems to be coming from the rt front when I hit a rough spot in the road. I'm thinking maybe bad strut but hate to go in blind replacing high dollar parts and working my way through. Any suggestions?
JRL
- Year and Model: Several
- Been thanked: 16 times
Spring seats or a sway bar link
dan777
- Year and Model: 2006 V70 2.5T
- Been thanked: 4 times
From my experience I can tell that if you hear a clonking noise when you go over a small bump with one wheel only at low speed, then most likely is the sway bar link...
Dan
2000 V70R (sold)
2006 V70 2.5T
2000 V70R (sold)
2006 V70 2.5T
If you open the hood and look under the strut washer (the round black rubber coated washer that the strut nut attaches to) you can most like see that the spring seat rubber is torn Or if you grab the end links to see if they are really loose, this should lead you to the problem. Check the support plate for corrosion and wear while you have the thing apart. Glück!
Macht's Gut!
v70t5driver
- Year and Model: v70 t5 2001
Like j5t said just twist with your hand that rubber piece on the top of the strut. If you can twist it then it's your spring seat and if it wont budge then it's something else. If the spring seat is the problem it will make a big knocking noise in the front and sway bar link problem is a clicking sound that you can notice at low speed. Hope this can help...
JRL
Sway bar link or spring seat
michaelisa
- Year and Model: S80 2005
I have an 05 S80 with 191k miles. Great Car. The car has developed a bumping in the left rear. It drives us nuts!! I have replaced the rear shocks and i have disconnected the stabilizer liniks. This did not fix it. I can make it "bump" when I push up and down on the car. Any suggestions will be greatly appreciated. Thanks!!
- 1225 Views
Last post by VolvoScout
- 1067 Views
Last post by thefisch
- 12 Replies
- 3462 Views
Last post by RickHaleParker
- 1532 Views
Last post by Dunks
- 2108 Views
Last post by MadeInJapan
