Hi guys, i had this code since a long time but this week end i decided to take care of this problem.Pretty simple what i did was lowering the exhaust, to do this i had to unhook the rubber pieces related to the exhaust and unbolt the 2 bolts holding the bracket in the center of the car. Removed the exhaust shield and once it's removed you can really see the canister. After last thing i had to remove is that fender liner, just drill the four rivets those towards the back of the wheel and the 2 10 mm nut and you can just fold the liner and you have acces and see the crack on the hose. After i just unhook the clamp by inserting a tiny screwdriver with a hammer, one shot and the clamp is removed. With a screwdriver(huge tip)
i unpluged the hose from the canister and cut about 1 1/4 inch from the hose (where the crack was) and then put it back in the canister with a new clamp. AND THAT'S IT The job was done took me about 2-3 hours and no more code.
p0442 j hose fix v70 2001
v70t5driver
- Year and Model: v70 t5 2001
- 2657 Views
- 1265 Views
Last post by zwieback
- 809 Views
Last post by RickHaleParker
- 2195 Views
Last post by jbkeene
- 13 Replies
- 6913 Views
Last post by VolvoBoron
